Laser cutter/engraver mod?
Hsiu
 Hsiu
(@hsiu)
Does anyone know if it is possible to mod a prusa printer to be a laser cutter or engraver? like if you could tape a laser onto the hotend and use that to engrave things?
Ce sujet a été modifié il y a 7 years par Hsiu
Publié : 02/11/2019 1:52 am
RE: Laser cutter/engraver mod?
Yes you can.
https://www.instructables.com/id/Laser-Engraving-on-Your-Prusa-MK3/
please follow all the safety advice and do at your own risk. I must emit I picked up a 2500mw laser to do this with but haven’t gotten around to doing it yet.
Publié : 02/11/2019 6:09 pm
There are special glasses that you can use that block the laser frequency.  They are a must have if you turn on that laser in the same room.  The light coming off a 1w laser will blind you instantly.  And your vision doesn't come back.
I recommend you buy the laser from a source that has matching glasses (not all lasers and glasses work together - they must be matched).
Seriously - know the safety protocols before flipping the switch.
Publié : 03/11/2019 7:30 am
