Keeping the Filament in the Printer-Enclosure
keks
 keks
(@keks)
I just got a Prusa Mini and want to build the Ikea-Lack Enclosure for it. Since there is a lot of spare space with the Mini, I want to place the Filamentspool inside the box. Can I do that, or is the increased heat bad for its quality (e.g. diameter consistency).
I am using Prusament PLA.
Thanks a lot in advance.
Publié : 15/11/2020 7:25 pm
RE: Keeping the Filament in the Printer-Enclosure
Posted by: @keksundso
For the Mini you do not need an enclosure. PLA is sensitive to heat accumulation, which can lead to blockages due to softening of the filament. A problem that was discussed very often here in the forum.
Printing PLA -> however, if you still want to use an enclosure because of the smells and some noise it produces, you must make sure that it is well ventilated.
Publié : 15/11/2020 7:39 pm
keks
 keks
(@keks)
@karl-herbert
thanks for pointing that out, did not know that.
Publié : 15/11/2020 8:17 pm
