Just a Question
Neal
 Neal
(@neal-3)
Just a Question
This is not a complaint I just seek knowledge. I have both an MK2S and MK3. Default speeds are 60mm/s and 80mm/s. Why does the MK2S consistently finish prints before the MK3? Even in Prusa Control the MK2S finishes first.
Thanks,
Neal
Postato : 09/09/2018 1:29 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Just a Question
So much depends on the model and acceleration/jerk settings. Unless the model has straight sides it's unlikely that you are getting to the requested print speeds
Peter
Postato : 09/09/2018 7:01 pm
Neal
 Neal
(@neal-3)
Re: Just a Question
That was my thought also. However I was printing boxes 200mmX100mmX160mm.
Well I was just wondering. That MK3 still creeps me out sitting over there making so little noise.
Thanks,
Neal
Postato : 10/09/2018 1:54 pm
PJR
 PJR
(@pjr)
Re: Just a Question
In that case, there's probably some slicer settings which are different; don't ask me which, I just don't have a clue!
I have generally found that with most prints, the Mk3 is slightly quicker.
Peter
Postato : 10/09/2018 2:34 pm
Phil
 Phil
(@phil-4)
Re: Just a Question
Since you mention the noise, you don't happen to have your MK3 in stealth mode do you? That will slow it down.
Postato : 10/09/2018 8:23 pm
