Identifing material used for part.
towlerg
(@towlerg)
I want to print a part which is quite challenging, so I'm going to try several materials. I could use a sharpie or whatever to mark the material used in the part but that will rub off after a while.
The ideal solution would be a stamp with the material name that you could apply within PrusaSlicer but unfortunately I have a vague memory of a Github request on the same line which was pooh poohed by the devs (albeit in a different context, the poster was interested in recycling).
Does anyone have a procedure for marking parts? I though perhaps X's with a chisel point soldering iron ie X=PETG, XX=ABS, XXX=ASA etc. Unfortunately my hand just isn't that steady.
Any suggestions.
Respondido : 27/11/2020 11:11 am
RedDawg
(@reddawg)
RE: Identifing material used for part.
Perhaps add the identifying letters in plain text, proud or incised, on a non-obvious part of the print, similar to how Prusa "brands" the Revision Number of some parts? Yes, you'd have to have a separate file for each material, but that should be a relatively simple matter.
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Respondido : 27/11/2020 2:21 pm
Miembro
Posted by: @towlerg
Any suggestions.
I do not but like this methodology.  Easier to read a number of X's
Respondido : 27/11/2020 4:19 pm
Miembro
Another option could be small half spheres as a cutout.
Respondido : 27/11/2020 4:22 pm
RedDawg
(@reddawg)
How about this?
Respondido : 27/11/2020 8:28 pm
RedDawg
(@reddawg)
More legible?
Respondido : 27/11/2020 8:36 pm
Miembro
@reddawg
I woul say it is.
Respondido : 27/11/2020 8:48 pm
towlerg
(@towlerg)
It doesn't help to include the id in CAD (unless you have the patients to general 3 or 4 STL's with different text).
So I went back to the github conversation and found the answer. You can load any STL as a modifier (right click, Add modifier, Load ...) so ALL I have to do is generate a part with the desired text and emboss in PrusaSlicer. This may take a while as CAD skills pretty poor.
PrusaSlicer really is getting pretty good although Cura still has a couple of tricks eg. tree supports, fuzzy skin.
Respondido : 28/11/2020 11:21 am
RedDawg
(@reddawg)
@towlerg
This is basically what I do in the CAD program; I have several "branding" phrases saved that I can just copy/paste them where I want them, then export to STL. Sure you can bring them into PruserSlicer as modifiers, but then orienting them, sizing and getting them "attached" to the desired surface can be pretty tedious. And if the desired surface is curved or non-orthogonal, forget it. Much easier done in CAD IMHO, YMMV.
Respondido : 29/11/2020 3:27 pm
towlerg
(@towlerg)
Yes I'm sure it's easier in CAD and positioning modifiers can be a pain but in this case I don't think I would remember to load different STL's.
One more complexity of making a modifier "punch" is that the text has to be mirrored.
Respondido : 29/11/2020 4:34 pm
PrusaPrinters profile
(@prusaprinters-profile)
How about that: https://en.wikipedia.org/wiki/Recycling_codes#List_of_resin_identification_codes_(RIC)_and_codes_defined_by_the_European_Commission ???
Respondido : 29/11/2020 5:32 pm
RedDawg
(@reddawg)
Unless the various codes/symbols are already downloadable in your preferred CAD format, you'll have to model them up yourself any, in which case you might as well use the actual abbreviations (ABS, PETG, PLA, etc.) instead of the code numbers and what they refer to, that I'd rather not clutter up my already addled brain with.
Respondido : 29/11/2020 6:18 pm
Well the are international use. So everyone know what does the mean here.
Respondido : 29/11/2020 7:21 pm
RedDawg
(@reddawg)
Unless the various codes/symbols are already downloadable in your preferred CAD format, you'll have to model them up yourself anyway, in which case you might as well use the actual abbreviations (ABS, PETG, PLA, etc.) instead of the arbitrary code numbers and what they refer to. Dunno about you, but I'd rather not clutter up my already addled brain with information like that.
Respondido : 29/11/2020 10:35 pm
RedDawg
(@reddawg)
Sorry, dunno how the duplicate got sent, maybe an admin can remove.
Respondido : 29/11/2020 11:15 pm
RedDawg
(@reddawg)
So I'm guessing there at least ten "exotic" plastic filament formulations that "we" use every day, but are relatively unknown, or at least not common enough to have their own International recycling code(s). Roll your own.
Respondido : 29/11/2020 11:33 pm
