How to make great time lapse videos without a Raspberry Pi
n808
 n808
(@n808)
It's still impossible to get a reasonably priced Raspberry Pi in my country, so I decided to get OctoPrint running on my Android phone.
First you need to install Octo4A: https://github.com/feelfreelinux/octo4a . Install the APK from Releases.
You need an OTG adapter, I got this from AliExpress.
You also need some kind of tripod: I printed this: https://www.thingiverse.com/thing:2489429
After you have OctoPrint working, it's very useful to setup PrusaSlicer to export and print directly via your phone now running OctoPrint: https://help.prusa3d.com/article/sending-files-to-octoprint-duet_1663
Some tricks: In order to install plugins to OctoPrint, on your phone enable "Install Plugin Extras" Options. This will install gcc, py3-devel and other required items. I installed a plugin for more accurate estimation of time remaining. Then I installed OctoLapse. However, the latest OctoLapse won't install due to compilation errors, but there's a branch that works fine: https://github.com/FormerLurker/Octolapse/issues/888#issuecomment-1476793545
Essential reading: OctoLapse Getting started. Once this is working, to get better quality videos, I changed from using the default libxvid to libx264. This results in much improved quality, but it may require a somewhat newer phone. It works fine on my Huawei P30 Pro. In order for OctoLapse to work, you have to enable Verbose gcode in PrusaSlicer.
Photo of my setup:
Example video (nothing exciting, just some nuts and bolts):
https://youtube.com/shorts/s_VlJqHkG5g
This topic was modified 1 year ago 2 times by n808
Posted : 28/07/2023 2:47 pm
ScottW
(@scottw)
RE: How to make great time lapse videos without a Raspberry Pi
Been using Octoprint (on Pi) for years, but never heard of Octo4A before.  Very cool!  Thanks for sharing the info.
Posted : 28/07/2023 7:31 pm
