How Tightly Can i Nest?
jared
(@jared-2)
Is there a down side to nesting parts as closely as possible? in PLA, is the below nest too tight? i ask because i had to manually place them in to get a tighter gap than the software (prusaslicer) has by default.
Este debate ha sido modificado el hace 4 years por jared
Respondido : 02/09/2022 7:18 pm
Robin
(@robin)
The spacing should be no problem, but depending on how good your bed adhesion is (all over the bed) and how tall the pieces are and how many times the nozzle crosses the parts, you have a high risk of one or more parts detaching and ruin your whole print. Might be a better idea to print less parts in one go.
If you use Octoprint you might want to consider https://plugins.octoprint.org/plugins/cancelobject/ or https://plugins.octoprint.org/plugins/excluderegion/ to at least be able to save part of your print in case something detaches.
Respondido : 03/09/2022 11:49 am
2 les gusta
jared
(@jared-2)
RE: How Tightly Can i Nest?
hey. thanks for stopping by. i've actually printed 1,000+ parts so far, so detaching issues yet. not even close, actually. a decent amount of work to get them all off the sheet for the next job. cheers 🙂
Respondido : 08/09/2022 8:55 pm
