Help with walls bowing outward on tall print
anon137
(@anon137)
Hello all! I'm having issues with the walls on this container bowing pretty bad. I've run all the calibrations from orca on the filament for optimal settings, I changed the order of wall printing Inner/Outer to Outer/Inner which helped a little, but I still have significant bowing. Any help would be greatly appreciated, thank you!
Best Answer by hyiger:
OK, this is basically a cooling problem. I would try lowering the nozzle temp to 200C, lower the bed temp to 45C after layer 3 or 4, crank the fan to 100% and set the minimum layer time to something like 15s. Also you can try changing the wall width to 0.40 instead 0.45. Also lower the outer wall speed to give the plastic time to cool
From what I remember, PLA+ is not the best material for this kind of print. You should probably just use regular PLA instead.
Opublikowany : 16/01/2026 9:32 pm
RE: Help with walls bowing outward on tall print
OK... but what filament? What settings? What kind of object? Could you provide the zipped 3MF file? Otherwise this is the equivalent of calling your doctor and simply saying "it hurts, what should I do?"
Opublikowany : 17/01/2026 4:25 am
1 ludzie polubili
anon137
(@anon137)
Filament: SUNLU PLA+ 2.0 Black
I've included zipped 3mf's, both orca specific and generic. Thank you
container
Opublikowany : 17/01/2026 1:36 pm
Opublikowany : 17/01/2026 5:05 pm
anon137
(@anon137)
I finally got back around to this print. Your advice worked! Thank you for your time!!!
Opublikowany : 02/04/2026 5:34 pm
1 ludzie polubili
Public username (required)
(@public-username-required)
You can change the heatnig, cooling, or fans at a specific height by editing gcode. This would not sacrifice the quality of the entire print just to fix one part.
Opublikowany : 07/04/2026 5:17 pm
