FlashForge Inventor With PrusaSlicer.
Rigger64
(@rigger64)
I recently had a Flashforge Inventor printer given to me it still needs some work to get both print heads in proper alignment but its getting there, i have also changed the build plate from Builders tape to a Magnitc PEI sheet.
I very much love using PrusaSlicer as aposed to the FlashForge software(USELESS) my question is how can i get the slicer to change the Print head to be able to do a color change midway through a print?
Opublikowany : 28/01/2026 11:38 am
Which version of g-code does it use?  Most likely you will need an M108 command but it could be a T  - what does the documentation of your printer say about these?
Opublikowany : 29/01/2026 1:22 am
Rigger64
(@rigger64)
RE: FlashForge Inventor With PrusaSlicer.
From what i have been able to find out it runs .GX files, which from what have been able to find is is " Modified, Binary G-Code format, & from what i have just found on the net is that if im using Cura that Marlin might work..
Opublikowany : 29/01/2026 1:38 pm
