Filament Vacuum Storage Level
sfshook22
(@sfshook22)
I was wondering what you use as a vacuum level for you filament packaging. I have a vacuum box that I can seal bags with for storage, but didn't want to crush the spools.
Thank you,
Steve Shook
Posted : 12/05/2019 11:58 pm
JMcK
 JMcK
(@jmck)
RE: Filament Vacuum Storage Level
I’ve used a vacuum food sealer. There was some deflection on cheap spools, and nearly empty spools, but nothing too bad.
When someone asks you if you're a god, you say, "YES!"
Posted : 13/05/2019 12:14 am
sfshook22
(@sfshook22)
Joe,
Thank you for the reply. I have almost destroyed (crushed) plastic containers using my vacuum box sealer.  😀 That was the reason for my question. At 0.13 MPa on a 200mm diameter surface results in quit a bit of force.
Steve
Posted : 13/05/2019 12:38 am
gnat
 gnat
(@gnat)
If you are worried about it, print some re-enforcements to support the edges.
MMU tips and troubleshooting
Posted : 13/05/2019 12:54 am
Antimix
(@antimix)
I use vacuum envelopes with silica gel inside.
They are available On Amazon.
I use the 40x50 measure that is more or less adequate for a spool, but there are bigger where you can put also two spools.
Regards
Posted : 13/05/2019 11:23 am
sfshook22
(@sfshook22)
Good idea, but the ones that I use are about 0.10 euros.
Thank you,
Steve
Posted : 13/05/2019 3:56 pm
payalguptha379
(@payalguptha379)
I use a Vacuum Sealer for that and it doesn't crush spools.
Posted : 24/11/2019 6:51 am
