Extruder motor is not working
eng.shaimaa.elsersy
(@eng-shaimaa-elsersy)
https://forum.prusa3d.com/wp-content/uploads/2020/08/video-1598135264.mp4
I have just assembled my new 3d printer and it was working good , i have printed 3 or 4 times , one of my prints is the picture above but suddenly it stopped extruding ,i unscrewed the 2 fans to move the hotend a little bit then i reprinted any of the files on SD but nothing worked also i set a small magnet in the extruder motor but i found that it rotated slightly as in the video so how can i solve my problem , thanks.
https://forum.prusa3d.com/wp-content/uploads/2020/08/video-1598136198.mp4
Best Answer by JoanTabb:
the motor gear in the bondtech pair, should be fastened with an M3x2 mm grub screw facing the flat on the Motor shaft
This topic was modified před 6 years 2 times by eng.shaimaa.elsersy
Napsal : 22/08/2020 10:52 pm
RE: Extruder motor is not working
Posted by: @eng-shaimaa-elsersy
Hello,
there may be a blockage in the hotend. Try cleaning the nozzle. It is best to heat the hotend to 260 degrees C. and use a nozzle needle. If this does not help, remove the nozzle and see if the hotend is blocked with a piece of filament. This can be pushed through carefully with a 1.5mm wire. The problem often occurs when printing PLA.
Napsal : 22/08/2020 11:19 pm
eng.shaimaa.elsersy
Hi, i removed the nozzle and i saw the hotend but nothing blocked inside it , also while removing the nozzle  i removed the upper screw and i found the bondtech gear is not stable , it moves freely , was this the reason ? or may be the problem in the motor itself , Thanks
Napsal : 23/08/2020 1:52 pm
Napsal : 23/08/2020 4:29 pm
1 lidem se líbí
eng.shaimaa.elsersy
Thanks A lot, it prints again, the problem was that the bondtech gear unscrewed .
Napsal : 23/08/2020 11:07 pm
