Enclosure ideas w/ Air filtration?
Yelmo
(@yelmo)
How has everyone created an enclosed system that filters the particles from prints? I have considered created an enclosure from clear polycarbonate, with a fan and HEPA filter on one side.
Things of Note:
  • Considering that some materials require stable air - the fan would need an on/off switch, only turning on after the print is complete.
  • Where can I find data on the size of the microparticles emitted? (to gauge efficacy of HEPA filters or soldering fume extractors)
Opublikowany : 22/06/2021 9:35 pm
RE: Enclosure ideas w/ Air filtration?
if you Google for Prusa enclosures you'll find a handful of commercial options, most--if not all--of which provide the option to add a filter. They're not cheap but if you print a lot of potentially dangerous filament types it may be well worth it. I can't recommend any in particular as 80% of what I print is PETG so I'm fine with a LACK enclosure for the occasional ABS.
Opublikowany : 24/06/2021 1:17 pm
1 ludzie polubili
Dan Rogers
(@dan-rogers)
I use a makergadgets enclosure - It came with a HEPA filter and active carbon filter built into the chamber, weather sealed doors and has an option for a programmable exhaust fan that I made a 2.5 inch duct adapter to fit.  The combination lets me run the enclosure closed (with the HEPA filter running) for printing ABS - this helps keep the temp up so warping is controlled nicely - and then the thermostatic exhaust fan will pull air (well above the print surface) out and let new air in.  The exhaust fan can be pre-installed so that it only exhausts air that has passed thru the HEPA and active carbon filter layers.  You can find their options at makergadgets.org.  It comes flat packed - you have to put it together - but that was part of the fun.  The folks at makergadgets.org are very supportive, and run a small biz selling enclosures and related gadgets.
Opublikowany : 24/06/2021 1:31 pm
1 ludzie polubili
gglockner
(@gglockner)
If your location allows it, even better than a filter is simply to vent the fumes to the outside. I added a clothes dryer vent to my wall and connected my enclosure to it. A fan inside the enclosure pushes the air out. This reduces the smell and health risks.
Opublikowany : 25/06/2021 8:56 pm
rosahampton487
(@rosahampton487)
An alternative to filters is simply venting the fumes outside of your location. A fan inside the enclosure pushes the air out. As a result, the smell and health risks are reduced.
Wellis Air
Opublikowany : 27/12/2021 10:30 am
ClarkGriswold
(@clarkgriswold)
Is the concern contamination from the printer to the surrounding environment or the other way around?  If it is the latter, you'd likely need an organic filter setup, but I can't imagine it being remotely necessary unless printing using unconventional filament that outgasses excessively.
Opublikowany : 08/01/2022 1:01 am
Yazzman56
(@yazzman56)
I am putting together aMMU2 case from 3dupfitters right now. You can an an optional charcoal filter which also has an outdoor venting hose attachment.
Opublikowany : 08/01/2022 2:43 pm
