Dryer connection
Phil
 Phil
(@phil-15)
Dryer connection
I am considering buying either the Sunlu dryer or the Polymaker dryer. In both cases, I have the same question. How do I connect the PTFE tube from the dryer to my Core One? The Polymaker comes with 50cm of PTFE tube. Is there a connecter I need to connect the tube from the dryer to the Core One input tube?
Prusa Core One
Opublikowany : 10/01/2026 3:23 pm
RE: Dryer connection
I would avoid the Polymaker dryer unless you only plan on using it with PETG and PLA. It can only reach up to 55C. I do however use the Polymaker dry boxes to store my filament. I use a PTFE coupler with a short length of PTFE tubing. Not the one that comes with the box, they are garbage. Too stiff so I just throw them out. Just pick up several meters from Amazon (or Alibaba etc) and cut as needed. If you want a decent dryer with a great UI, I would suggest the Creality Space Pi 4
PTFE Tube Kit
PC4-M6 Pneumatic Straight Fitting
Polymaker PolyDryer Box PC4-M6 Coupler Adapter
Opublikowany : 10/01/2026 4:06 pm
Phil
 Phil
(@phil-15)
Thanks hyiger. It is confusing because one thread says the Polymaker dryer or Sunlu are great. I never heard of the Creality Space Pi 4. It looks good, but $200. ouch this is an expensive hobby.
Prusa Core One
Opublikowany : 10/01/2026 5:04 pm
mnentwig
(@mnentwig)
>> Creality Space Pi 4
+1 on that one (I got mine after hyiger recommended it months ago).
But, work with what you've got. Just run for 24 hours - you can't do permanent damage to regular filament types by over-drying. I find it hard to imagine 55 °C would leave enough moisture to be an issue. The diffusion speed of water in plastic increases strongly with temperature so you may just have to wait a little longer than what a higher-temperature-dryer could achieve.
For the ASA I'm printing I have to stay well below Space Pi's maximum settings or the bone-dry filament gets unworkably brittle and some (depending on brand) spools deform.
Opublikowany : 10/01/2026 5:23 pm
Posted by: @mnentwig
Yup. The absolute worst were the Prusament spools with the cardboard inserts. If you were drying PC, PA or PP you had to wire or bolt the plastic ends of the spool together or the adhesive on the cardboard would soften and cause the spool to fall apart. A very, very, very stupid design. They've since fixed this with the new spools but took them 5 years.
Opublikowany : 10/01/2026 5:34 pm
Posted by: @phil-16
"Great" is a very subjective term. It really depends on your use case. If you are printing mostly PETG, PLA or TPU then the Polymaker dryer is totally fine. If you are using PA (nylon) then it is totally useless. Sunlu is OK but it has a crappy and hard to use UI.
Compared to my other hobbies, 3D printing is relatively cheap. If you want a very inexpensive hobby that can allow you to create your own things, try knitting 🙂
Opublikowany : 10/01/2026 5:39 pm
Phil
 Phil
(@phil-15)
I am not using PA. I just ordered a spool of TPU. But right now I need to dry my PETG cuz I am getting stringy prints.
Prusa Core One
Opublikowany : 10/01/2026 6:53 pm
Posted by: @phil-16
Not using PA now, but who knows?
For PETG, it's not as convenient as a dedicated dryer, but you can dry the filament in your printer. Set the bed to 60°, place the spool flat then cover it with half of a filament box. Leave it there for 5-6 hrs. For the TPU do not trust that it will be dry fresh from the box. I strongly recommend immediately drying it after removing for the packaging.
Opublikowany : 10/01/2026 7:30 pm
Bruce Labitt
(@bruce-labitt)
For any filament, do not trust that it will be dry out of the box.  I had two spools of Prusament PETG that hissed and popped when printing.  And it was the first PETG that I ever printed.  Dried the filament and it was great.  Before drying, it wouldn't even stick to the bed on the first layer.  I thought my printer was broken!  It wasn't, it was just very wet filament.
I now print direct from a dryer.  Doesn't matter what it is, I use the dryer now.  My dryer will go up to 85C.  And it was a lot more expensive than I ever expected.  But it made for successful prints.  There's nothing more disappointing than having a nine hour print get botched.  Try that a few times in a row...  That was TPU, before I learned about dry filament.  Never had print failures after that due to moisture issues.
Opublikowany : 11/01/2026 2:15 am
Phil
 Phil
(@phil-15)
I ordered the Creality Space Pi 4 and 2 Polymaker Dry Boxes. Thanks for all your suggestions. Especially, hygier's comment about "not printing PA now, but who knows?" This is so true. I don't want to be blocked from printing what I want.
BTW, I've ordered the PTFE kit, fittings and printed the couplers in PETG.
Prusa Core One
Opublikowany : 11/01/2026 4:51 pm
PETG for the couplers is a solid choice but they will eventually wear out when you start printing abrasive filaments. I printed mine in PC Blend.
You'll love the Space Pi 4. It has a very intuitive screen and I like the fact it has independent chambers so I can dry two different types of filament at the same time.
Opublikowany : 11/01/2026 4:59 pm
Artur5
(@artur5)
Just a few hints taken from a very reliable source (Fillamentum, Czech manufacturer of high quality filaments ).
1- You can -and you will-  damage some types of filament not only by overheating, but by drying it too many hours as well.
2 - Unlike some drier manufacturers say, you won’t dry well TPU at low temperatures (50-55C)  no matter how many hours you leave the spools it in the drier. In fact trying to dry TPU at 50C is worse than not drying it at all, because  at those temps. the filament absorbs water faster than at room temperature. For TPU you need at least 80C to dry it well, but you can’t do that more than two or three times with the same spool. After that the filament starts to degrade.
3- You can damage nylon by drying it several hours at temperatures higher than 80-85C. That goes for annealing too. Above 85C many nylon polymers starts to oxo-degrade and the mechanical properties go downhill fast. Some nylons might be more sensitive than others of course, but be careful.
Opublikowany : 11/01/2026 9:24 pm
Concerning TPU, that is mostly correct. Depends on the formulation. Always best to check the data sheet.
With regard to nylon, depends on the specific blend but most nylons (especially PA6) require some moisture or they become too brittle to print. So you can over dry them. However, this is (usually) a temporary condition. You can just leave it out in the open for an hour or two and it should be good to go.
Opublikowany : 11/01/2026 10:24 pm
Phil
 Phil
(@phil-15)
I finally received my Creality dryer and Polymaker dry boxes. I also rcv'd the PTFE kit and PC4-M6 Pneumatic Straight Fitting from amazon that hyiger recommended. I printed the couplers in PETG, for now.  One last question, how do I connect the PTFE from the dry box to the PTFE input of the Core One? I know this seems like a lot of hand holding, but I am totally new to 3d printing. Thank you all in advance.
Also, if I want to spool directly from the Creality dryer, is the connection any different than you've shown in the above Polymaker dry boxes?
Prusa Core One
Opublikowany : 17/01/2026 4:48 pm
Phil
 Phil
(@phil-15)
BTW, I love how you the Creality dryer chambers run independently and even one can be off while the other side is drying. Saves power.
Prusa Core One
Opublikowany : 17/01/2026 4:53 pm
Phil
 Phil
(@phil-15)
Ok, after opening hygier's picture above I see a white couple at the Core One. What is that? And where do I get one?
Prusa Core One
Opublikowany : 17/01/2026 5:01 pm
Posted by: @phil-16
The come with the PTFE tube kit: https://www.amazon.com/dp/B0F27YQF27?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_55&th=1
Opublikowany : 17/01/2026 5:08 pm
1 ludzie polubili
Phil
 Phil
(@phil-15)
Is there a MAX distance from the Core One to the dry box>
Prusa Core One
Opublikowany : 17/01/2026 5:16 pm
Posted by: @phil-16
Yes, it is the length of your filament.
So the short answer is "no".
Opublikowany : 17/01/2026 5:48 pm
1 ludzie polubili
Phil
 Phil
(@phil-15)
thanks for all your help, hyiger
Prusa Core One
Opublikowany : 17/01/2026 6:52 pm
