Do you provide 3D printing services?
juice
(@juice)
Hello PRUSA team, I am a new user to 3D printing. I hope to get your professional advice and help here. Recently, I have been studying the field of handcrafting, which has great potential. There are many customized customers and the demand is also great. I usually encounter a problem. Purely handmade, large quantities are too busy. If you combine 3D scanning and printing equipment, By scanning your own works with a 3D scanner and 3D printing them, you can break through the labor ceiling, demand will come, and everything will be fine.
If I use a 3D scanner to model my own model and give you the data, can I provide 3D printing services? Of course, my demand is relatively large. If it can be realized, that would be great.
Or can you recommend me a simple-to-operate 3D printer that even a novice can get started with? It doesn’t need to be particularly expensive in the early stage. The size of my figure is about 30mm-150mm.
I will be very much looking forward to your suggestions
This topic was modified 2 years temu by juice
Opublikowany : 22/05/2024 8:35 am
RE: Do you provide 3D printing services?
I don't understand?
Opublikowany : 22/05/2024 2:27 pm
Find nearby printers via: https://world.prusa3d.com/
Opublikowany : 22/05/2024 2:36 pm
