Core One Quality Issues
Beatus
(@beatus)
I've been having more quality issues lately and don't know what's causing them.
Maybe one of you has some advice.
I'm printing a large container that almost fills the entire heating bed.
I'm using Prusament Galaxy Black filament.
The heating bed temperature is 60°C, nozzle 222°C.
The underside is printed incorrectly, see photo 1.
In the corner at the front left edge, the filament comes loose, even when I print something that fills the entire surface of the heating bed (see photo 2).
Thanks for any tips.
Best Answer by mnentwig:
Moisture? Make sure the filament is dry. It's the single most important issue...
Respondido : 21/02/2026 10:22 am
Beatus
(@beatus)
RE: Core One Quality Issues
With underside I mean the side that lies directly on the heatbed.
Respondido : 21/02/2026 10:24 am
alphasigma
(@alphasigma)
Posted by: @beatus
nozzle 222°C.
...the nozzle temperature doesn't fit to Prusas preset for their own PLA filament!
You have an adhesion problem, yes PLA also can warp. Stick to the preset profile!
Place a brim around larger parts or add the "famous"  mouse ears - called "helper disk" in Prusa Slicer -> add part -> Gallery -> move it to the edge, max 1 layer height!
Avoid "sharp" corners, make round corners when designing yourself.
Core One L
Respondido : 21/02/2026 12:32 pm
1 les gusta
mnentwig
(@mnentwig)
Respondido : 21/02/2026 12:40 pm
Mac-N4MCC
(@mac-n4mcc)
Recommend starting with the Prusa Research configurations in the slicer until you figure out the idiosyncrasies of your printer. I had this problem also. TRy going up or down ten degrees at a time, and work that. Print a temp tower for that filament and your printer.
Extra HAM (and eggs some say) Radio - N4MCC
Respondido : 23/02/2026 4:53 am
Beatus
(@beatus)
Thanks. I did not know the helper disk.
Respondido : 24/02/2026 6:07 pm
Beatus
(@beatus)
Thank you. This was the point I think. I thought it would not be necessary to put the PLA in a dry box, because it was not indicated on the Prusa Material sheet.
This was a mistake.
Posted by: @mnentwig
Respondido : 24/02/2026 6:10 pm
1 les gusta
