clearly PLA was not the right choice - what filament do you recommend?
Rob Latour
(@rob-latour)
I printed a bunch of these using PLA:
https://www.printables.com/model/481346-solar-light-fence-bracket-brace
and they looked great until yesterday where I live it reached over 35 degrees celsius and this happened:
https://ibb.co/sJ9YrNG
Also, it gets very cold where I am; -30 degrees celsius or below.
While I suspect it would be better to print with a lighter colour, I would like to print in black so to that they look good on the fence.
I have a MK3S, what is the best type of filament should I be re-printing them with?
Postato : 01/06/2023 2:21 pm
René
(@rene-3)
RE: clearly PLA was not the right choice - what filament do you recommend?
PLA is a great kind of filament.
But not suitable for outdoor use.
The material cannot withstand high temperatures and UV rays shining through the sun nicely in your garden.
I think ASA, ABS or nylon are better suited for your object.
Postato : 01/06/2023 2:36 pm
Walter Layher
(@walter-layher)
Even PETG is a lot better suited for outside use. I have several PETG prints that have been outside for years and get quite a bit of direct sunlight, like a weather station, a bird feeder, some attachment brackets etc. and they show no sign of degradation so far. PETG is also easier to print well than ABS/ASA.
Postato : 01/06/2023 3:56 pm
1 persone hanno apprezzato
RedDawg
(@reddawg)
I can also recommend PETG, but black might be pushing it because of higher heat absorbshion. Try one and test before committing to the lot.
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Postato : 01/06/2023 4:37 pm
PETG, PETG-CF, ASA, ABS, etc. all good choices. See the Prusa materials table for details: https://help.prusa3d.com/materials
Postato : 01/06/2023 4:51 pm
Rob Latour
(@rob-latour)
Thanks I just ordered some PTEG.
Postato : 01/06/2023 5:18 pm
jsw
 jsw
(@jsw)
I use ABS or ASA for items that will be used outdoors or in a hot car.
PLA will most definitely sag.
Postato : 01/06/2023 9:58 pm
For this sort of job I've recently been using: https://3dtomorrow.com/product/3dtomorrow-biopro-3d-printer-filament-1kg-1-75mm/   It stands up to heat and UV well.
'though in your case PETG might be enough if you can protect it from UV, a good quality paint is your best protection but you will need a primer suitable for PETG.
Postato : 01/06/2023 10:45 pm
