Cleaning Nozzle after color change?
Lobby
(@lobby)
Folks,  I changed filaments after a few layers on a recent print and had a problem with excess filament on the nozzle after the change.   In this case, I went from TPU to PETG, but this has also happened with merely changing from 1 color PLA to another color:   the filament change leaves too much filament on the nozzle, messing up the print.
Am I missing a setting in PrusaSlicer?
Is there a software / hardware change that's needed?
Thanks!
MK4S upgrade from MK3s
Veröffentlicht : 24/12/2024 12:14 am
Filament curling up and sticking to the nozzle is sometimes a symptom of nozzle wear and sometimes of damp filament - but TPU is more likely than most to stick to coated and ceramic nozzles.
About the only setting that might be worth changing is the Purge Volume.
Veröffentlicht : 24/12/2024 6:41 am
RE: Cleaning Nozzle after color change?
I don't think you're going to get much from prusaslicer in that regard. I'd invest in some precision forceps and just grab everything from the nozzle. In my hands that seems to do the job pretty well.
Veröffentlicht : 24/12/2024 1:16 pm
Eds_3D_Odyssey
(@eds_3d_odyssey)
I like to use a Wipe Cylinder when printing with 2 or more colors. You can see my settings here.
https://www.printables.com/model/1066505-god-helps-you-handle
https://www.printables.com/@Eds3dOdyssey
Veröffentlicht : 25/12/2024 11:01 am
UjinDesign
(@ujindesign)
Perhaps I'm missing what the problem is, but when I do color changes and I want to clean the nozzle in-between (which is very rare btw), I just clean the nozzle manually after the 1st filament is unloaded but before the 2nd filament is loaded.
Veröffentlicht : 29/12/2024 6:15 pm
