Change layer thickness, change Z height (offset)?
mjlewis37
(@mjlewis37)
Thanks to the experienced users who have answered my newb questions! I'll try to word this question to help others (if this makes any sense).
So, my first print with a 0.4mm nozzle at 0.3 layer height using PETG and I get bad layer adhesion. A layer height of 0.2mm worked fine, so I just changed my first layer height in PrusaSlicer to 0.2mm. This gave me a good first layer. My Live Z on the Prusa I3 MK3 is set to give a good 0.2mm first layer with PETG.
The question: When raising layer heights, should you in PrusaSlicer give a corresponding negative Z offset in the printer settings? Say I go from 0.2mm to a 0.3mm layer height, I put in a negative 0.1mm Z Offset in PrusaSlicer?
I want to get a handle on this before I get larger nozzles and increase the layer height even more.
This topic was modified před 6 years 2 times by mjlewis37
Napsal : 26/08/2020 10:42 pm
RE: Change layer thickness, change Z height (offset)?
No. Basically just leave that first layer height at 0.2 and set the rest to whatever you need/want. Or go to town and use variable layer heights for the rest.
One of the main reasons the first layer has its own height setting in to give you a consistent basis to print from.
Napsal : 26/08/2020 10:48 pm
