Bridges and or overhangs.
John Lindo
(@john-lindo)
Can this bridging and overhang terminology be explained further.
The way I see it and me being a non engineering expert " overhang is when a portion of a vertical wall  juts out, a bridge normally connects 2 portions
of overhangs.
Unfortunately "gravity" gets in the way of extended overhangs and bridges were built with appropriate arcs come to the rescue and even allowing
a pathway to cross.
I recently watched a you tube video showing revised settings of the Prusa slicer 2.6 and getting totally confused with recommended speed settings.
Could the recommended speed settings for overhangs be calculated using a spread sheet ? distance of overhang versus versus the
setting of the filament temperature ?
I still think the way to go is using the organic support option.
Thanks
John
Spain
Opublikowany : 28/08/2024 4:18 pm
