“Basic” Buddy Camera Question
Razor
(@razor)
Having never used a camera before, I decided to purchase the newly announced Buddy Camera for my XL. I’m starting to run longer multi hour prints, and this will be nice to have.
As I’m waiting for it to arrive, it is my understanding that this is not something that connects directly to my XL. I will need to connect the camera to either a nearby computer, or a Raspberry Pi running Prusa Connect? Is this correct? Thanks.
Best Answer by Werwerf:
Howdy!
Just bought it and installed it.
Indeed, it just connects to power via USB C to USB A cable (provided). You have to configure "New Wifi Cam" and show the QR code you create with your Wifi info to the camera to set it up. Once it connects to the Wifi, it automatically appears in your camera section in Prusa Connect.
WORD OF WARNING: DO NOT USE DARK MODE when creating the QR Code!!!! I almost went crazy trying to pair the camera until I changed to make the QR code in light mode. Then, it connected flawlessly 🙂
Here a sample of the camera working with IR (night mode)
BuddyCam in IR mode
Mini+MK3S+XL 5 Tool
Publié : 30/11/2024 2:55 pm
JP Guitars
(@jp-guitars)
RE: “Basic” Buddy Camera Question
Reading through the description, my interpretation is the only physical connection will be to a usb power supply and the connection to Connect will be via wifi
Publié : 30/11/2024 3:02 pm
2 personnes ont aimé
Razor
(@razor)
Ok, that makes sense now, thanks! I hope that’s the case. That would make it super easy.
Mini+MK3S+XL 5 Tool
Publié : 30/11/2024 3:05 pm
Werwerf
(@werwerf)
Membre
Howdy!
BuddyCam in IR mode
Publié : 30/11/2024 3:51 pm
_KaszpiR_
(@_kaszpir_)
hm looks like it has focus set to about 30cm? Can you adjust it somehow to make a sharp picture to the elements closer to the camera?
Publié : 30/11/2024 9:10 pm
So is it basically just an ESP32-CAM in a nice body?
Publié : 30/11/2024 11:33 pm
JP Guitars
(@jp-guitars)
Posted by: @foxrun3d
With a clever QR code setup routine and later motor control of where it points
Publié : 30/11/2024 11:59 pm
Jdwilsonaz
(@jdwilsonaz)
The XL has a USB-C port on the system board that should power the camera.
Publié : 05/12/2024 5:09 pm
ssmith
(@ssmith)
I've used that port for serial com, but it does not provide power.
Publié : 05/12/2024 6:20 pm
James Kirk
(@james-kirk)
@werwerf: So I guess, there is not really a life stream, but similat to the esp-cam just a picture every 10 seconds?
And no possibility to do timelaps-videos?
So, the only adavantage is, that you can see the picture in prusa connect.
I think I will stay with my "standard" security cam (e.g. tapo). --> life stream, night vision, motor driven movement. Only thing is, it´s not inside prusa connect.
Publié : 07/12/2024 8:45 am
A few months ago I added esp32 cams to all my printers. I found them to be very unreliable, going offline all the time requiring a reboot. Plus it's only snapshots in PrusaConnect, not live streams. And with the mega monster fan of the Mk4S, the placement that worked well on the Mk4 is now unusable. I'm actually going back to the Wyze cams I used before and will be removing the ESP32's. Only downside is I need to open a separate app but will have a live streams, all the time.
Publié : 07/12/2024 10:48 am
Werwerf
(@werwerf)
Membre
Yes, it is very basic (no Timelapse or live stream). But suits me as plug and play for a very reasonable price. Prusa has announced more features to come directly from Connect, so works for me 😊
Publié : 07/12/2024 1:11 pm
Razor
(@razor)
From the announcement in the blog, “We’re also working on adding the highly requested livestream feature.”
Posted by: @james-kirk
Mini+MK3S+XL 5 Tool
Publié : 07/12/2024 1:15 pm
1 personnes ont aimé
Macmagoo
(@macmagoo)
My buddy camera has a horrible cyan cast all over the photo in natural light. I would have thought Prusa could have done better than this when selecting a camera for a very expensive printer.
Publié : 22/12/2024 1:16 pm
_KaszpiR_
(@_kaszpir_)
Cyan overlay sounds like a cable ribbon not properly set in the socket and some pins not contacting.
One option is to try to fix it yourself. Another is to request a warranty repair.
Publié : 22/12/2024 3:11 pm
Macmagoo
(@macmagoo)
It is a Buddy camera supplied by Prusa it connects directly to a USB socket there is no ribbon or pins.
Publié : 22/12/2024 3:26 pm
_KaszpiR_
(@_kaszpir_)
True, I didn't explain it well enough.
What I mean that inside the camera there may be a loose cable between the camera board and the rest of the electronics that is inside it. so you could try to disassemble it to fix it (and assemble it back).
I suggest reporting it to Prusa, because it should return normal colors, no overlayed ones at all.
Publié : 22/12/2024 7:32 pm
