Are files created by PrusaSlicer or SuperSlicer interchangeably?
prusanewuser
(@prusanewuser)
Hi, can a .3mf file created by either program be modified in another and then load back to the original program and re-modified? Will there be messing up?
Posted : 24/04/2021 1:47 pm
RE: Are files created by PrusaSlicer or SuperSlicer interchangeably?
You can upload them.  I have yet to see an issue with bringing them between programs.
Posted : 25/04/2021 11:58 am
It depends on what versions and it also depends on what features/settings.  I have had ones where you cant open them interchangeably in the past.
That was with PS 2.2 and Susie 2.2.54 though.  With 2.3 and 2.2.55/2.2.56 its try it and see territory.  I think you are safer going from PS to Susie though rather than the other way around, as Susie has more settings and when importing a project that has missing settings (like one imported from PS) it tries to add them with the default that setting would normally have.
Do be aware that any version of Susie beyond 2.2.54 (stable) will potentially have bugs in and it is not guaranteed to work properly so always check your slice preview VERY carefully for unintended things.
Posted : 25/04/2021 12:27 pm
