Anyonr know what can be causing this print issue?
Seem to always happen when i use a 0.6 nozzle.. i use the standard settings and just up the print speed via the printer. Its seems to alway leave a rough finish where the retractions are. I have tried several different retraction distances/speeds but i still get the issue?
Opublikowany : 01/03/2023 2:44 pm
RE: Anyonr know what can be causing this print issue?
Without seeing the STL and your settings (try uploading a zip compressed 3mf file of your project) it's all guesswork. I've seen artifacts of this type with thin walls that didn't have optimized extrusion width and/or gap infill. One simple experiment to try is to switch from Arachne to classic perimeter algorithm.
Opublikowany : 01/03/2023 11:06 pm
