Any Idea what would cause this in the 1st layer?
Ted
 Ted
(@ted-6)
I just changed my nozzle to a 0.6 and replaced the print bed with the steel sheet.  Calibration went smooth and looks correct.  PLA is new.  Top layers of final print are smooth.  a lot of the 1st layer looks perfect. Wondering why the 1st layer looks this way.
Postato : 17/08/2022 4:40 pm
RE: Any Idea what would cause this in the 1st layer?
Looks like live z too low?
Postato : 17/08/2022 5:46 pm
Erik
 Erik
(@erik-6)
Agreed that z offset is too low.
The built-in first layer calibration routine is set for a 0.4mm nozzle. Best option for a 0.6 nozzle is to use a 40mmX40mm
X 0.3mm pad (can use a model from Printables, or use built-in shapes in Prusa Slicer), set for 0.3 QUALITY layer height setting.
Also keep in mind that all three spring steel sheets (smooth, satin, textured) have different thicknesses, and require different z offsets. You can save each one so you don't need to re-run every time you change the sheet.
Erik
Questo post è stato modificato 4 years fa da Erik
Postato : 21/08/2022 1:59 am
Ted
 Ted
(@ted-6)
Thank you.
Postato : 24/08/2022 4:22 pm
