3D benchy that floats?
PatFarrell
(@patfarrell)
I'm new and don't know if this is the right place. I've made some 3D Benchy's from the Prusa SD card and my wife thinks they are cute. She thinks I should make some for our grandkids. But they don't float.  I'm assuming this is a FAQ: is there a version of the Benchy that has been modified to float and is useful as a bathtub toy?
I assume this won't require a naval architect, just someone a bit more familiar with Fusion 3D than I am.
Thanks
Pat
Napsal : 08/04/2022 2:39 am
RE: 3D benchy that floats?
This is where google should be your first stop.  https://www.3dbenchy.com/3dbenchy-gets-floating-assistance-by-dsb-007/
Napsal : 08/04/2022 6:27 am
PatFarrell
(@patfarrell)
Posted by: @neophyl
Actually this caused me to do a better Google search, for "toy boats"
I don't really need a "Benchy™" just a fun boat for the bathtub
Napsal : 10/04/2022 1:52 am
Er, it does require a certain amount of naval architecture...
The Benchy is a waterline model of a cartoon vessel - actually most benchies ever printed will float - just not the right way up.
It shouldn't be too hard to print a hull that could be glued to a benchy to complete the structure.  It would need to be deeper than you might expect and to pause for a weight to be inserted, like the lead keel of a yacht, to correct the metacentric height.   A major complication would be calculating the weight as the size would be a function of the infill percentage of the superstructure.
And then the default perimeters and layers used to make a Benchy *look* good are not very waterproof so water would tend to seep into the model...
Stick with those model boats and apply waterproofing paint or varnish.
Napsal : 10/04/2022 12:15 pm
1 lidem se líbí
p1mrx
(@p1mrx)
You can make a Benchy float upright by tweaking the infill, though in the bathtub you have to be careful not to splash water over the sides:
https://www.printables.com/model/514921-floating-benchy-density-hack
Napsal : 30/04/2025 5:28 pm
