2.0mm nozzle on a Prusa
Renan Teuman
(@renan-teuman)
Hello All,
I have a prusa coming on the way. I was wondering if anyone have used a nozzle with as wide as a 2.0mm diameter. From what I understand prusa has a different kind of nozzle then other printers, so I'm not sure if I can mount any nozzle into the prusa.
In the help page the width goes up to 0.8mm https://help.prusa3d.com/article/different-nozzle-types_2193
If anyone can let me know if you have done this or where I can find a 2.0 mm nozzle for prusa please let me know!
Thank you all
Renan
Postato : 22/09/2022 1:15 pm
RE: 2.0mm nozzle on a Prusa
Prusa offer profiles for 0.25, 0.4, 0.6 and 0.8 mm nozzles.
Probably best using.0.25 nozzlesi expect 0.2 would work with the 0.25 extrusion values
Regards Joan
Postato : 22/09/2022 2:21 pm
Renan Teuman
(@renan-teuman)
Hi Joan, thanks for your reply. I need a 2 mm thick nozzle, not 0.2!
R
Postato : 22/09/2022 2:40 pm
I do a lot of 0.8 mm printing but haven't gone beyond that. I'd be concerned about the stock hotend's ability to melt and push filament fast enough.
Postato : 22/09/2022 3:19 pm
Robin
(@robin)
I don't think you can extrude 1,75mm filament through a 2,0mm nozzle, even if the hot end would generate enough heat to melt it... You would need a bottleneck in the nozzle to make sure the filament gets contact to the metal to get heated and enough pressure to fill the lower 2,0mm diameter part of the nozzle fast enough to extrude evenly- sounds very unlikely.
Postato : 22/09/2022 3:42 pm
Ringarn67
(@ringarn67)
I think it is impossible. I mean, filament is 1,75mm thick, how do you melt and squeeze it through a 2mm hole??
I know about 3mm filament, but that´s not for stock Prusa...
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Postato : 22/09/2022 3:50 pm
The largest nozzle diameter available on the market is 1mm. For example, you could drill a 0.4mm nozzle to 2mm, but you will not get sufficient results with a 1.75mm filament. And even if it works, the heating element will not be able to feed enough material (limited volumetric speed).
( https://nozzleboss.de/?product=v6-nozzle-10mm-messing-175mm-fuer-e3d-e3dv6)
wbr,
Karl
Postato : 22/09/2022 5:02 pm
1 persone hanno apprezzato
Renan Teuman
(@renan-teuman)
Thank you Karl, then I imagine the largest I can go would be around 1.5mm, if I drill 0.4mm nozzle. What do you think?
R
Postato : 22/09/2022 5:11 pm
As I always say -> the proof of the pudding is in the eating. The 1.5mm hole should have a smooth surface and burr-free.
(left: good, right: sub-optimal)
wbr,
Karl
Postato : 22/09/2022 6:14 pm
K7ZPJ
(@k7zpj)
Typically 3D printer that use large nozzles, use 2.85mm filament / hot ends to be able to meet the flow requirements of the larger nozzles.
Just making the nozzle size larger doesn't do any thing to increase the capacity of the  hot end so it can support that kind of flow rate.
Postato : 22/09/2022 6:53 pm
