Wonky Rocket
Sean
 Sean
(@sean-6)
Wonky Rocket
Wonky Rocket from Thingiverse
Respondido : 27/07/2018 4:49 am
Calire
(@calire)
Re: Wonky Rocket
Wahou beautifull fine and funky très chouette et marrant 😀
Respondido : 27/07/2018 5:58 am
Re: Wonky Rocket
A lot of people are having a hard time with layer seams on rounded and cylindrical surfaces. Would you mind sharing your slicer settings? Did you do any post-processing?
Respondido : 27/07/2018 8:58 am
Miembro
Re: Wonky Rocket
Care the share the file? That would be a great trophy for a school rocket launch.
Respondido : 27/07/2018 2:22 pm
Sean
 Sean
(@sean-6)
Re: Wonky Rocket
Here is the link to the original design on thingiverse,
https://www.thingiverse.com/thing:2918546
The reason that the spheres look smooth is because I airbrushed the part with white acrylic paint. Trust me it had layer lines!
Respondido : 28/07/2018 5:01 am
RufusClupea
(@rufusclupea)
Re: Wonky Rocket
Did you do the same/similar with the rocket? I was looking for layer lines on the nose area.
BTW, what keeps it from falling over--are the clouds weighted with something?
Beautiful model/print/job. :geek:
That's "MISTER Old Fart" to you!
Respondido : 15/08/2018 5:48 pm
Sean
 Sean
(@sean-6)
Re: Wonky Rocket
Maria, HI! No I certainly can't take credit for the model. See the link to Thingiverse above. 300ZXCOLIN Is the fellow who created it.
Rufus, Yes I white primer painted the rocket and finished it with Krylon Metalic spraypaint. I should have taken some pictures of the unpainted print. I will make sure I do that in the future. There were actually some gaps where the nose cone meets the needle that I had to fill in with bondo.
The clouds are 20% infill so the base is heavier than the little rocket. The entire model is pretty light!
Respondido : 16/08/2018 5:48 pm
