T-Rex @ 110% and 220%
RobertB67
(@robertb67)
I seen the T-Rex on thingiverse and wanted to print one, so I printed it at 110%:
but now I was wondering how big I could print this T-Rex, so here it is at 220% next to the 110% T-Rex
Napsal : 23/09/2018 3:32 am
Calire
(@calire)
Re: T-Rex @ 110% and 220%
Superbe, grandiose, génial, i love it, amazing ...
At 220% no problem ? for a big bone you split in two parts, how much ?
Napsal : 23/09/2018 8:34 am
RobertB67
(@robertb67)
I did not have to split any of the parts. One of the pieces I cut off part of the clip that would slide inside the other part but since I was gluing it I did not care, I just put extra glue into that hole where the clip goes into to make sure I had a strong joint. The Post I had to print it diagonally.
The 220% T-Rex is about 52 inches (132cm) Long and about 20 inches (51cm) Tall.
Had it on display at my Library's Make Space for a few weeks.
Napsal : 23/09/2018 10:46 pm
RufusClupea
(@rufusclupea)
Let us know when you print one life-size... 😀
That's "MISTER Old Fart" to you!
Napsal : 24/09/2018 8:41 am
1 lidem se líbí
Steve
(@steve-3)
They are amazing. Do you recall the total print times for each version?
Steve
Napsal : 24/09/2018 6:35 pm
RobertB67
(@robertb67)
Steve
Sorry do not really keep track of print time. Most of it was hit print and go to sleep or print and head to work.
Napsal : 24/09/2018 8:27 pm
toby.k
(@toby-k)
Well done, both the print and your photos.
What filament and color did you use? The color in the photos actually looks like bone.
Napsal : 25/09/2018 12:11 am
RobertB67
(@robertb67)
Paramount 3D PLA (Pantone 468C Skin - Fair Complexion) 1.75mm 1kg Filament [LIRL1015468C]
https://www.amazon.com/gp/product/B01N7R2CZL/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
I use Paramount 3D a lot, love the way it prints and they have very cool colors. Never had a problem with the filament. It runs mostly aroaund $21-23 and some special colors are $29
Napsal : 25/09/2018 12:34 am
HB
 HB
(@hb)
did you have to cut som of the big parts i half and print separately (then glue them together) ? or did you just scale up to 220%?
i plan on printing this myself and want it as big as possible:)
Napsal : 25/09/2018 7:42 am
RobertB67
(@robertb67)
Napsal : 25/09/2018 5:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
I printed this at 175% (and the Stegosaurus at 170% ) a couple of years ago on the Mk1, with a smaller bed.
Only problem is that the vertical support needs a metal insert (straightened wire coat hanger) as it starts to bend after a few hours display in the sun 🙁
Near the end of this video:
Peter
Napsal : 25/09/2018 6:01 pm
