Supply Reel Spaghetti Ball
RedDawg
(@reddawg)
A couple of times I have suffered the Supply Reel Spaghetti Ball syndrome (see photo) when large excursions of the X-axis cause windings on a full or almost full reel to "overflow" the reel and tangle around the spool holder's horizontal element. I have been using a small C-clamp (colored red in the photo) to constrain the feed path somewhat, but it failed miserably here, as you can see.
I recall seeing (Here? Thingiverse?) a filament guide that clips onto the upper frame element (similar to the dual spool support bracket)  that provides a filament entry point very close to the spool  edge to keep this from happening, but I cannot now locate it. Does anyone else recall seeing this guide, and can you please provide a link to it. Or do you have other solutions?
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Napsal : 27/05/2021 2:34 am
RE: Supply Reel Spaghetti Ball
Something like this:
https://www.thingiverse.com/thing:2986472
Napsal : 27/05/2021 2:38 am
RedDawg
(@reddawg)
That's not the one I remember seeing, but it certainly looks like it will do the job. I'll try it. Thanks for the link.
Napsal : 27/05/2021 3:02 am
@reddawg
Did it have a round or oval hole?
Napsal : 27/05/2021 3:03 am
This is another one that is closer to the spool.
https://www.prusaprinters.org/prints/2016-prusa-i3-mk-filament-guide-clipon
Napsal : 27/05/2021 3:04 am
RedDawg
(@reddawg)
@cwbullet
IIRC, it was round and only slightly larger than 1.75mm filament.
Napsal : 27/05/2021 3:24 am
MichaelK
(@michaelk)
@reddawg
This one
https://www.thingiverse.com/thing:1657908
Or this one
https://www.thingiverse.com/thing:1940114
Napsal : 27/05/2021 4:20 am
There are a huge number of options out there.  I would just pick on and try it.  If it does not work for you, just print another.  I printed one and I am going try to incorporate it into my spool holder.
Napsal : 27/05/2021 9:26 am
Smaller hold option:
https://www.prusaprinters.org/prints/31539-filament-guide-for-prusa-i3-mk3s
Napsal : 27/05/2021 10:42 am
jsw
 jsw
(@jsw)
Here's the one I use.  I think it came from here.
Attachment removed
Napsal : 27/05/2021 8:29 pm
