Spool Hubs
I've designed & printed 2 spool hubs for my printer. They are printed out of PLA at .15mm layer height. They are press fit onto a 0.375 inch drill rod and hold the spool on center. The hub center hole ID is 0.375 inches. The printed ID was slightly smaller so I ran a 0.375 inch drill through the parts to clean them up.
The assembly fits perfectly on the PRUSA spool arms that came with the printer. The spool now turns smoothly as the printer pulls in the filament instead of the hopping the spool used to make.
Publié : 07/07/2017 9:50 pm
Topic starter
answered:
Re: Spool Hubs
I've just posted the models on GrabCad if you are interested. They are titled Spool Hub.
Publié : 07/07/2017 10:24 pm
