Harry Potter RavenClaw Crest
Gelap
(@gelap)
This was my first attempt to use multiple color filaments on a print. I had tried to use PrusaColor to set the color change layer heights, but it indicated the model was .5 mm taller than it was. I didn't want to risk a long build with the transitions happening at the wrong levels, so I used the new PrusaControl. It worked like a charm, though it would have been nice to have a little more control over the settings. I understand its aimed at beginners but maybe add an expert mode to change infill and/or perimeters?
If I ever print it again, I'd probably swap the grey and possibly the light blue for white.
I tweaked an existing model off thingiverse and uploaded the remix.
https://www.thingiverse.com/thing:2390776
Napsal : 22/06/2017 7:30 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: Harry Potter RavenClaw Crest
Nice print!
Napsal : 23/06/2017 12:19 am
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Anthony, would you mind if I share your print on Prusa3D pinterest page? Thank you
Assembly manuals
/ Knowledge Base
Napsal : 10/07/2017 9:03 pm
Gelap
(@gelap)
jakub.d - I do not mind if you post the print on the Prusa3D pinterest page. Thanks.
Napsal : 15/07/2017 5:27 am
AJS
 AJS
(@ajs)
A very nice print. For future reference, if you print with Z Hop, it lifts the head 0.5mm when moving. This messes up PrusaColor as the Z is constantly going up and down. For PrusaColor, you need to use "Original Prusa i3 MK2 ColorPrint" not "Original Prusa i3 MK2 with ZHop" as the "Printer" setting.
Napsal : 16/07/2017 3:23 am
Gelap
(@gelap)
aaron.s5 - Thank you very much for that insight.
Napsal : 18/07/2017 1:56 am
