Grumpy Pumpkin
Gelap
(@gelap)
Grumpy Pumpkin
Given the season, I thought I'd share. This model came out completely perfect, looks like I finally have things dialed in.
Orange Inland PLA
0% Infill
.2mm Layer height
70% Scale (82% is the max)
102 Flow
https://www.thingiverse.com/thing:159638
The model has some weird internal structures I removed with Meshmixer and re-flattened the bottom.
Currently printing a smaller one (35%) in vase mode which I will light up.
Publié : 21/10/2017 7:35 pm
insider
(@insider)
Re: Grumpy Pumpkin
What are you slicing with? Using Slic3r and vase mode isn't handling the angles v well near the top. Non vase mode isn't doing great either!! Very impressed with what I see.
Rory
Publié : 22/10/2017 2:23 am
JeffJordan
(@jeffjordan)
Membre Moderator
Re: Grumpy Pumpkin
very nice !
why did you need to increase the extrusion (flow) by 2% ?
is it to correct uncalibrated extrusion at your site ?
Publié : 22/10/2017 11:25 am
Gelap
(@gelap)
Re: Grumpy Pumpkin
rory.c: For the big one, I used the latest PrusaControl slicer. For the small one in vase mode, I tried Simplify3D. As you can see, your concerns about handling the angles near the top are well founded.
Since my plan was to light it from the bottom with a tealight, those little gaps aren't too bad.
I did a small one with PrusaControl and light it and the effect is great, but I would need to use a more powerful light source.
JeffJordan: I use a few brands of PLA and for most the default flow is fine. While the base was being laid down, I noticed it was a little under extruded so I bumped it up a little. I spot checked the filament in a few places and its a hair shy of 1.75mm in most places. For $15 a Kg, its still a great value.
If time permits I may crop the top off in such a way as too leave the face in the front but lower the back to use as a candy bowel. At 87% scale, it could be a bit bigger since the Z dimension is currently maxing out first.
Publié : 22/10/2017 7:53 pm
insider
(@insider)
Re: Grumpy Pumpkin
Anthony - still looks good enough for me to give it a try! - thanks - Rory
Publié : 22/10/2017 9:16 pm
your.o
(@your-o)
Re: Grumpy Pumpkin
^Yeah, it still turned out great anyway.
It looks like the pumpkin you made have waited all year long for this season! :mrgreen:
Publié : 24/10/2017 1:10 pm
