Card Cases
erik.d
(@erik-d)
Card Cases
Hello there,
I was warking on some cool card cases (2 and 1 slot), so here they are - older are ugliest. After gaining some experience, tha last one (ferrari and F1) are my best so far
Opublikowany : 11/03/2017 3:27 pm
erik.d
(@erik-d)
Re: Card Cases
My first try (AK-47) and second try
Opublikowany : 11/03/2017 3:29 pm
erik.d
(@erik-d)
Re: Card Cases
Here are some other
Opublikowany : 11/03/2017 3:30 pm
erik.d
(@erik-d)
Re: Card Cases
Latest one
Opublikowany : 11/03/2017 3:31 pm
MechLink
(@mechlink)
Re: Card Cases
very nice I like the different styles.
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Opublikowany : 11/03/2017 4:47 pm
erik.d
(@erik-d)
Re: Card Cases
Another ones
Opublikowany : 15/03/2017 5:59 pm
Marc
 Marc
(@marc-9)
Re: Card Cases
Can you give us some details on how you printed them?
Details like material used, nozzle diameter, layer height, etc...
Opublikowany : 16/03/2017 9:05 am
Chris Abbey
(@chris-abbey)
Re: Card Cases
Is there anything that secures the cards in other than friction?
Opublikowany : 16/03/2017 6:00 pm
erik.d
(@erik-d)
Re: Card Cases
Well deatails are:
Latest and best verion of card cover comprises of 3 parts:
-body (mid)
-2x cover with logo (support used)
Both are printed with different technique. Covers and logos are printed with 0.25mm nozzle and 0.1mm layerheight, Printed in one piece face (logo) down (just switched colors in between). Multi colored parts of logos are printed separateley and then glued into cover (i have nice Virtus pro cover, coming soon).
Body, or mid, is printed with 0.4 nozzle, 0.5 extrusion width (because walls are 1mm/2mm thick), also support is used. There is nothing to secure cards except friction, but it's well designed because it is both horuzontal and vertical fricion which are preventig card from drop out. Material is PLA. I use this cover on daily basis
Opublikowany : 24/03/2017 9:14 pm
TΩNI
(@tni)
Re: Card Cases
where are the stl or gcode files for this case
Opublikowany : 25/03/2017 11:09 am
erik.d
(@erik-d)
Re: Card Cases
In my computer 😀
Opublikowany : 25/03/2017 3:20 pm
Marc
 Marc
(@marc-9)
Re: Card Cases
Thanks very much for the information Erik!
Opublikowany : 26/03/2017 5:48 pm
erik.d
(@erik-d)
Re: Card Cases
You are welcome. It needs some more editing, so work is in progress. Just be patient and i will put here stls. Here are another covers
Opublikowany : 27/03/2017 7:21 pm
erik.d
(@erik-d)
Re: Card Cases
Here are some .stls. I cant guerantee it will fit for your card, because every card is slightly different. However, it should fit well, for most of cards
Opublikowany : 03/04/2017 9:50 pm
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Re: Card Cases
Dear Erik, would you mind if I share your print on Prusa3D Pinterest page? Thank you
Assembly manuals
/ Knowledge Base
Opublikowany : 10/07/2017 11:02 pm
