Prusa Filiament
mikenoyce
(@mikenoyce)
Prusa Filiament
I recently purchased a roll of white PETG filament from PRUSA.  When printing with it, it run out of the extruder like a soft toothpaste?  I am using Prusa's recommended temperatures. I am using It this a bad batch?  Anyone figure out when is the best temperatures for if?
Opublikowany : 23/08/2019 7:16 pm
RE: Prusa Filiament
What specific temperatures?
Opublikowany : 24/08/2019 1:01 pm
mikenoyce
(@mikenoyce)
RE: Prusa Filiament
230
Opublikowany : 25/08/2019 10:23 pm
mikenoyce
(@mikenoyce)
RE: Prusa Filiament
All the other pets colors from Prusa work great, it is just the white that is giving me problems.
Opublikowany : 25/08/2019 10:25 pm
Dave Avery
(@dave-avery)
RE: Prusa Filiament
i think whites ( from everyone ) are hard to print because of all the titanium dioxide used to turn natural to white. i suspect you will need to run hotter and maybe slower
Opublikowany : 26/08/2019 4:12 am
mikenoyce
(@mikenoyce)
RE: Prusa Filiament
I'm not sure hotter is the answer, it's already pretty soupy.
Opublikowany : 26/08/2019 4:15 am
RE: Prusa Filiament
I would lower the temp by 5 degrees until you get the results you want.
Opublikowany : 26/08/2019 12:49 pm
3Dprintedgr
(@3dprintedgr)
RE: Prusa Filiament
Posted by: @mikenoyce1
Did you find a solution to this problem? I have ordered a white PETG and wondering if I will come across the same problem.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Opublikowany : 02/11/2019 8:16 pm
