Prusa Filiament
I recently purchased a roll of white PETG filament from PRUSA. When printing with it, it run out of the extruder like a soft toothpaste? I am using Prusa's recommended temperatures. I am using It this a bad batch? Anyone figure out when is the best temperatures for if?
RE: Prusa Filiament
230
RE: Prusa Filiament
All the other pets colors from Prusa work great, it is just the white that is giving me problems.
RE: Prusa Filiament
i think whites ( from everyone ) are hard to print because of all the titanium dioxide used to turn natural to white. i suspect you will need to run hotter and maybe slower
RE: Prusa Filiament
I'm not sure hotter is the answer, it's already pretty soupy.
RE: Prusa Filiament
I would lower the temp by 5 degrees until you get the results you want.
RE: Prusa Filiament
Did you find a solution to this problem? I have ordered a white PETG and wondering if I will come across the same problem.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
