Simple face shield - help with stacking?
Hi all, The face fields from Prusa are awesome, but require more time and materials to print. It's hard enough getting supplies right now so I'm using a model from 3dverkstand.se that I modified slightly (the fracture point at the front was cracking too easily so I smoothed it out).
I'd really like some help if someone can instruct me on how to stack these so they print and can be broken off separately on a Prusa i3 mk3. I tried to look up the info but I can use one of you gurus to help. I've attached the file, please let me know how I can stack these. https://www.thingiverse.com/thing:4253822 It's the file titled: Flattened_Mask.stl
Thanks in advance!
Best Answer by Sembazuru:
See this thread for some tips and tricks:
https://forum.prusa3d.com/forum/prusaslicer/stacking-how-to-set-up-in-prusaslicer/
RE: Simple face shield - help with stacking?
I also want to know this.
Prusa MK3S with MMU2S
Prusa Slicer 2.1
Could you share the settings you are using to print this on your mk3? I'm having trouble with the sides getting printed with a gap in the middle.
@steve-b8
I'm not printing any stacked, I'm asking if anyone knows how to set it up so I can print a stack to make sure it comes out right...
See my (limited) designs on:
