Quick Way to Punch Holes in 100 Transparancies
jurassic73
(@jurassic73)
Drill them!  Used an 11/64" bit.  Lucked out in that these transparencies shipped shrink wrapped else I was going to have to clamp them together to make the holes.  Drilled four holes to make 400 holes.  Nice and consistent.
Used these: https://www.amazon.com/gp/product/B07KZKQBZ5/
MK3s / My IKEA Lack enclosure
Veröffentlicht : 01/04/2020 2:42 am
mitch.w
(@mitch-w)
RE: Quick Way to Punch Holes in 100 Transparancies
What spacing did you use? I tried the 888 (2 inner holes centered on page and 8cm apart, two outer holes 8cm from inner) but it does not fit.  Not sure if I am using wrong pattern, or if my print scale is off?
Veröffentlicht : 02/04/2020 7:04 pm
jurassic73
(@jurassic73)
Posted by: @mitch-w
I made one by hand.  I took one sheet and held it up to the shield frame and marked where the holes should go and then I transfer that to my stack.  Just make sure you go off the base of the peg.
Veröffentlicht : 03/04/2020 2:17 am
John
 John
(@john-6)
In case you don’t see the drill press in the first photo, I don’t recommend drilling with a hand held drill.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Veröffentlicht : 03/04/2020 9:03 am
