Quick Way to Punch Holes in 100 Transparancies
Drill them! Used an 11/64" bit. Lucked out in that these transparencies shipped shrink wrapped else I was going to have to clamp them together to make the holes. Drilled four holes to make 400 holes. Nice and consistent.
Used these: https://www.amazon.com/gp/product/B07KZKQBZ5/
MK3s / My IKEA Lack enclosure
RE: Quick Way to Punch Holes in 100 Transparancies
What spacing did you use? I tried the 888 (2 inner holes centered on page and 8cm apart, two outer holes 8cm from inner) but it does not fit. Not sure if I am using wrong pattern, or if my print scale is off?
I made one by hand. I took one sheet and held it up to the shield frame and marked where the holes should go and then I transfer that to my stack. Just make sure you go off the base of the peg.
In case you don’t see the drill press in the first photo, I don’t recommend drilling with a hand held drill.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
