Can you print the face shields using the Prusa MINI
Can you print the face shields using the Prusa MINI ?
Opublikowany : 12/04/2020 7:10 pm
RE: Can you print the face shields using the Prusa MINI
If Mini has bed size 18x18 then vesion RC2 and RC3 will not fit, you can play with rotate but I doupt that. Version RC1 will fit.
May be good tip for Prusa, to make a version for Mini. It needs to be just a bit narrower, but not so much as RC1.
Opublikowany : 12/04/2020 8:10 pm
Go to Prusaprinters Page and search for "mini face shield". There are various versions, including a US and EU version depending on which hole punch you are using to make the holes in the clear visor material.
Cheers,Dave Jackson"Enthralled Nooby (not so much maybe, ~58 years old)... If 3d printers had been around 40 years ago... "
Opublikowany : 13/04/2020 9:17 am
