Why does the flow change automatically?
it goes from 100% to 95% why?
Best Answer by sylviatrilling:
This number of 95% comes from the default g-code which is easy to change. See
Postato : 18/03/2022 9:48 am
Postato : 18/03/2022 9:51 am
RE: Why does the flow change automatically?
Mk3S+,SL1S
Postato : 18/03/2022 2:03 pm
Tojik hanno apprezzato
We should probably make it 95% in the UI by default, not waiting for the printer to report it
Postato : 18/03/2022 2:34 pm
sylviatrilling hanno apprezzato
I just looked into a gcode, it's more complicated, the value gets reset when the print ends. Making the default 95% would make sense as to not throw off the default slicer flow settings, but there is no default default, it titer-toters between 95 when printing and 100 when idle. What a horror to work around this.
Postato : 18/03/2022 3:19 pm
Henry hanno apprezzato
