Upload to subfolder from PrusaSlicer with PrusaConnect
geekQ
(@geekq)
I would like to organize printing files by folder.
In PrusaSlicer, "Send to printer" > Upload shows a hint:
use forward slashes (/) as a directory separator if needed.Upload to storage: usb
If I use PrusaLink in Printer Settings, it works fine - uploads to a subfolder on the USB stick connected to Printer.
But when I try the same with PrusaConnect, it also tells "subfolder1/test1_PETG_MK3.5_17m.bgcode -> ... The file was successfully uploaded to Connect and is being downloaded by the printer." But the file lands in the root folder of the USB stick instead.
Is it a known issue with PrusaConnect and PrusaSlicer? Or am I missing something regarding file/path-format?
A mitigation, and also a useful feature on its own, would be the ability to reorganize - move, rename existing files in PrusaConnect and possibility for a full sync between USB stick on the printer and the state in the cloud (PrusaConect).
I am using the latest PrusaSlicer 2.7.4, latest MK3.5 Firmware 6.0.1+14848, printer UUID: 0dcbd56c-eabb-4608-8ceb-bbcb0b723b19
This topic was modified 11 months ago by geekQ
Posted : 26/05/2024 11:27 am
geekQ
(@geekq)
RE: Upload to subfolder from PrusaSlicer with PrusaConnect
Additional information: I am using PrusaSlicer on Linux - just in case path handling (bugs) are platform specific
Posted : 27/05/2024 10:50 am
BryceDMG
(@brycedmg)
Were you ever able to find the issue or a fix? I'm running into the same issue when I try to upload using Prusa Connect on a Windows-based laptop. PrusaSlicer Version 2.9.1.
Posted : 12/03/2025 4:39 pm
yodakubota
(@yodakubota)
Having the same problem. Forward slashes seem to be removed as the filename uploaded on PrusaConnect seems to be the path, but without slashes... Root directory it is for now...
Posted by: @brycedmg
Posted : 29/03/2025 9:49 pm
