Upload to local storage issue
The upload does not finish, it stays (pic below). The process can be canceled, but the file is never uploaded.
type Original Prusa i3 MK3S
firmware 3.10.1-4697
Prusa Link 0.6.0
Connect SDK printer 0.6.0
RE: Upload to local storage issue
I couldn't save via PrusaConnect today. I uploaded two files and next didn't work. It just showed me 0%. Via PrusaLink without any problems.
- firmware 3.10.1-4697 PrusaLink - Raspberry Pi Zero, version 0.6.0
Moi aussi
The same here. The upload over PrusaLink is fine, but the moment it has to go through prusas servers it shows 0% and does nothing.
Will have to hop on this, same problem with Prusa Connect, Prusa Link is fine
Hi, this "works" in the dev version. It's in two parts. Upload is the file going up to the connect servers. Then there's transfer, during which it downloads the file from connect onto the rPi SD. I can still break it by uploading a file before the previous finishes transferring, but that's still being worked on.
