The Print Queue not having the Duplicate button activated
[Solved] The Print Queue not having the Duplicate button activated
ajbooter
(@ajbooter)
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4) = Raspberry Pi Zero 2
PrusaLink version =0.6.1
Printer type = Original Prusa i3 MK3S/+
Printer UUID (you can find it in Printer detail page - address line) = ?
Printer firmware versionPrusaSlicer version (if applicable) = 3.11.0-4955
Description of the bug, including steps to reproduce (if possible).
In the Print queue all of my gcode files have the Duplicate button grayed out and not functioning. When I hover over the disabled Duplicate button it states "File is not available on the printer." I have to go to the Printer files -> Prusa Lnk gcodes and find it again to then put it in the queue again. With the prior version of Prusa Connect, the Duplicate file process worked as expected.
Posted : 21/03/2023 5:11 pm
ajbooter
(@ajbooter)
RE: The Print Queue not having the Duplicate button activated
The new release today fixed the issue. Thank you and keep up the great work.
Posted : 23/03/2023 6:14 pm
