the backend has moved to the darkside
DocPO
(@docpo)
Utenti
My printer is behaving really strange.  I cannot get it to start a print, but I am not getting errors on uploading.  It printed just fine this morning and then after changing the filament out, it would print again.  I have resliced and tried to print directly from PursaSlicer as well as trying to print a file that was uploaded before it started to fritz out.  When i looked at logs in prusa connect I got ""  The LCD screen occasionally does a little flash but it is inconsistent.  I can see files after they upload, but I cannot get them to start. The LCD screen has the OK: 192.____ (the normal numbers).  I have tried restarting the printer several times and have had no luck.   On prusa connect it is listed as "ready".
I even flashed updated firmware to the printer and I see that update in connect.
I am able to print to my other printer in the same room from connect.
I am still running 0.5.2 because it was working well and I am uncertain how to update that without needing to entirely set up the printer again.  I am happy to try that if needed though.
Thank you for the help.
Postato : 20/01/2022 10:32 pm
DocPO
(@docpo)
Utenti
RE: the backend has moved to the darkside
Update: I pulled the Pi and flashed 0.6.0 onto it and wizarded the printer and it is now working.  Kinda strange, but I have no idea what happened.
I would still like to know if anyone has any ideas on what happened.
Postato : 20/01/2022 11:05 pm
