Stop on bed leveling error
tampe125
(@tampe125)
Hello,
from time to time I have issues with the machine being stuck in a loop where it keeps to calibrate on Z axis and tries to perform bed leveling. Since most of the time my printers are running unattended, is it possible to have some kind of option to simply kill the print run instead of calibrating?
Some more context: all my printers are equipped with the Jobox hardware, so they can run almost 24/7 . From time to time, they fail to correctly deploy the bed sheet, so the height sensor doesn't trigger. Obviously this always happens at night, so when I wake up I find that one machine has spent the last 4 hours trying to Z calibrate and then perform the bed leveling...
Having some kind of switch would be awesome.
Publié : 03/11/2023 8:44 am
Hello
(@hello)
RE: Stop on bed leveling error
Posted by: @tampe125
Hello,
This is something to contact support about none of us use the jobox setup. Photo would be cool 😎
Publié : 03/11/2023 5:53 pm
tampe125
(@tampe125)
Sure, here you can find some pictures. In one you can see what I mean when the bed is not correctly positioned, it stays raised and it's causing the calibration loop.
In the other you can find the whole setup: beds are on the back, when the print is completed they are ejected. You have to apply to the original heating bed a small aluminium sheet with grooves that will make the beds move back and forth. Honestly it's a clever design, I hoped Prusa itself have developed it ages ago 🙂
https://photos.app.goo.gl/7k9SMWPZXU3qtM1m9
https://photos.app.goo.gl/kAw8sb3RAXxMiqay5
Publié : 04/11/2023 10:38 am
Hello
(@hello)
So your problem is the z axis leveling, correct ? If so have you tried it when it's stock
Publié : 04/11/2023 7:46 pm
tampe125
(@tampe125)
No, you're missing the point.
From time to time the bed doesn't snap in place. This could happen for several reasons, but my point is: it's possible to halt the print instead of forcing the Z calibration?
Publié : 04/11/2023 8:12 pm
https://jobox.tech/pages/troubleshooting
Publié : 05/11/2023 12:27 am
Tojik
(@tojik)
Membre Moderator
Hi, sorry, i will not get to implement that. Stop on repeated MBL fails. If anyone wants to take a crack at this, the code is on github, if it's done semi-nicely+ it might get merged
Publié : 06/11/2023 10:14 am
tampe125
(@tampe125)
Ok, seems fair, since this is a very edge case. Maybe I can check current machine status from the API. Just as a quick question, is there a way to check what's current printer status and if there's a warning, what's the reason for the warning?
My idea is to create a python script that will check for the status of the machine and if it detects that it's inside a calibration loop, simply kill the print.
Publié : 06/11/2023 10:18 am
Tojik
(@tojik)
Membre Moderator
It sends out "Bed leveling failed. Too much variation from eeprom mesh" when the Z calibration fails, but to stop it, you would need to reset the printer. You can do that from within PrusaLink. It is jank, but it might work for you.
If you want it to reset on every message like this, make a regex like this one. Put it into the regular_expressions.py
Z_CALIBRATION_FAILED_REGEX = re.compile("^Bed leveling failed. Too much variation from eeprom mesh$")
Then in prusa_link.py
self.serial_parser.add_decoupled_handler(Z_CALIBRATION_FAILED_REGEX, lambda sender, match: self.z_calibration_failed())
and somewhere in the method section:
def z_calibration_failed(self) -> None:
    """ Pauses the print, when fw asks to through serial
    This is activated by the user most of the time """
    prctl_name()
    command = ResetPrinter(source=Source.FIRMWARE)
    self.command_queue.enqueue_command(command)
That should probably do it
Publié : 06/11/2023 10:36 am
