Raspberry Pi PrusaLink Image won't start after reboot command
DanielAttia
(@danielattia)
It may just be that I'm a novice at this, but I have been having this issue since I started to use PrusaLink on my Raspberry Pi 4. I have used Linux before, but each time I run the command "sudo reboot" it doesn't reboot properly and I need to manually unplug the Pi from power to reset it.
I have followed the following instructions from the README.md file without much luck
To start Prusa Link on boot, add this line to `/etc/rc.local`
su pi -c 'prusa-link start'
Any help or advice is appreciated!
Best Answer by madpro:
Not a good idea normally - had same issue on Rpi3B . After adding the custom file, try   (sudo reboot --force --force).  Worked for me.
Opublikowany : 03/12/2021 3:26 pm
madpro
(@madpro)
RE: Raspberry Pi PrusaLink Image won't start after reboot command
Opublikowany : 07/12/2021 4:19 pm
Tojik
(@tojik)
Member Moderator
The script in rc.local now looks like this:
rm -f /home/pi/prusa-link.pid
export PYTHONOPTIMIZE=2
su pi -c '/home/pi/.local/bin/prusa-link -i start'
Sorry, I haven't updated the README in a long time.
There might be a problem with a thread refusing to die, which would prolong the reboot ~2 mins, but it should die eventually.
Opublikowany : 15/02/2022 4:06 pm
1 ludzie polubili
