PrusaConnect & Prusalink can't delete files
Antimix
(@antimix)
MK4 6.0.0-14794
Hello,
I sent a gcode from PrusaSlicer to my MK4 and then, before I printed it, I realized that there were two unused objects on the bed. So I deleted them, re-sliced the bed and sent the new job to the printer.
Then to avoid mistakes, I went in PrusaConnect in the file section to delete the wrong job, and suprise surprise, it can't be deleted.
The delete option is greyed. 😤
I tried with PrusaLink, and I got the same behaviour 😧
Why I can't delete this job ?
Can be that unprinted  jobs can't be deleted ?
Regards
Best Answer by Antimix:
Hi, it's over one hour now and the print is finished, and now automagically 😆 the delete button is enabled again.
I have deleted the never printed job.
I suspect that the MK4 or PrusaConnect/PrusaLink when the printer is printing has something slowing it down during the print.
Now the the printer is idle, all commands were fast an immediate.
Solved.
Regards
Opublikowany : 10/05/2024 2:21 pm
Brian
(@brian-12)
RE: PrusaConnect & Prusalink can't delete files
I just deleted files a few minutes ago without issue.
Do you get an error message?
Opublikowany : 10/05/2024 4:23 pm
Antimix
(@antimix)
Solved.
Regards
Opublikowany : 10/05/2024 5:31 pm
2 ludzie polubili
