Prusa Connect issues with using the SetRead function
chaos777b
(@chaos777b)
Miembro
Trying to use the print queue through Prusa Connect with my new MK4. The MK4 has just finished a job and is still in the Finished state and the Set Ready option fails to change the status of the printer.
On the MK4 navigating back to main menu puts the printer into Idle Mode through prusa connect. There does not appear to be a way to set the printer to ready from the printer it self.
When the printer is idle and Set Ready option works and the printer pics up the job from the print queue.
I cant find any documentation if this is the expected behavior or a BUG.
Best Answer by Tojik:
Hello, the SetReady not working in the FINISHED state is a bug. That should hopefully be fixed in the next update. We know about the absence of a set ready function in the printer menu. It should get added in the future, after we figure out where to put it 🙂
Respondido : 28/07/2023 10:36 pm
Tojik
(@tojik)
Miembro Moderator
Respondido : 31/07/2023 10:22 am
