Printer displays 'Sliced for different printer' warning incorrectly (printer model check)
Michiel Haisma
(@michiel-haisma)
  • Printer type - MK3S + MMU2S
  • Printer UUID (you can find it in Printer detail page - address line) -
  • Printer firmware version - 3.14.1  / 3.0.3
  • PrusaSlicer version (if applicable) - 2.9.4
  • Description of the bug, including steps to reproduce (if possible): After updating the firmware, printer will show a warning when a GCODE file is chosen from SD 'sliced for different printer' (paraphrased), even though, the printer should match (and has not been changed in the slicer. The problem can be created as follows: take an (old) MK3S  with MMU2S and flash both to latest (above) firmware versions. Create a gcode using prusaslicer with the version above designed for the printer 'Original Prusa i3 MK3S & MK3S+ & MMU2S'. Transfer gcode file to SD Card. Insert SD card into printer. Turn on printer. Select 'Print from SD' from menu. Select sliced file. The warning is displayed even though it should not be (it prints correctly).
My personal thoughts is that when they unified (did they?) the firmware for MMU2S and MMU3, now a MK3S+MMU2S thinks it's an MMU3, so the warning will show. I checked the GCODE in notepad and it shows:
M862.3 P "MK3SMMU2S" ; printer model check
So the GCODE is correct, but the printer firmware complains.
Posted : 21/06/2026 12:16 pm
Check your firmware download - it is easy to download one for a slightly different machine version ...
And if you upgrade a printer and download the correct new firmware any stored gcode that previously worked will fail and need re-slicing with the new settings.
Posted : 22/06/2026 4:54 am
Michiel Haisma
(@michiel-haisma)
RE: Printer displays 'Sliced for different printer' warning incorrectly (printer model check)
Posted by: @diem
It's the correct one: MK3S_MK3S+_FW_3.14.1_MULTILANG.hex
And for the MMU, the firmwares now are combined: MMU2S_MMU3_FW3.0.3+896.hex
Your comment regarding new firmware with old GCODE is simply false. GCODEs are (mostly) not firmware specific. As I also said, no GCODEs are failing, they are displaying a warning when they should not. Also, that happens with new GCODE files on new firmware.
Posted : 22/06/2026 6:47 am
Contact Prusa Support via chat.
One of the first things they will ask you to do is check the firmware number the MMU has:
On your LCD menu go to  Support and scroll down until you see MMU2 connected, FW: - and a firmware number
You may as well get that ready.
Posted : 22/06/2026 12:01 pm
Michiel Haisma
(@michiel-haisma)
Already posted that information in the OP.
Posted : 22/06/2026 12:06 pm
