PC loses connection to Printer after failed upload during current print
Ochia Satawri
(@ochia-satawri)
I've had this happen 5x times so far.
If the printer is in the middle of a print, and I upload the g-code using PrusaSlicer network transfer, it has caused PrusaConnect to loose connection with the printer.
I cannot access PrusaLink via IP address either, and I get a timeout if I ping the IP address.In order to regain access, I need to power cycle the printer.
Using Pi Zero 2W with 0.6.1.PrusaSlicer 2.5 on MacOS (however did it with 2.4 as well)
Opublikowany : 29/04/2023 2:47 pm
Tojik
(@tojik)
Member Moderator
RE: PC loses connection to Printer after failed upload during current print
Hi, this version is really old at this point. I know we did not post one in a while. There are releases on github, the most recent being 0.7.0 RC3, but it has one big flaw. Makes your printer beep ll the time. So either wait for the next one, or put your printer on silent for the time being. Sorry about that. https://github.com/prusa3d/Prusa-Link/releases
Opublikowany : 02/05/2023 12:18 pm
