[Solved] Network Error on MKS+
ajbooter
(@ajbooter)
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4) = Raspberry Pi Zero W
PrusaLink version = 0.6.1
Printer type = Original Prusa i3 MK3S/+
Printer UUID (you can find it in Printer detail page - address line) = 3bc2ccf1-1a25-46f3-9213-afd9d8039d6d and c17a414b-f32b-44b1-b1c7-fbff20aa7ede and f32b3e91-6882-4a20-bbc4-6a2a6a9809fd
Printer firmware version = 3.12.2-5713
PrusaSlicer version (if applicable) = 2.5.2 64Bit
Description of the bug, including steps to reproduce (if possible). I have been getting a Network Error on the machines all of them seem to be having this issue. The display on the machine will show ERR: then the network IP address. My network for everything else seems to be fine even on the 2.4 GHZ WiFi. The machines go in and out of this state. I have reset the machines and even turned them off and back on. I have reset my network but it seems to not matter. I have had to start using the SD card again for some prints because when I need to start a print I can not get the machine to start. This was not happening as much until about a week ago and now it is regularly happening. Any help would be nice. I have 3 machines and that is why I have 3 UUIDs shown. Thanks for you assistance in this matter.
Best Answer by Tojik:
Hi, yes, Connect was having problems over the weekend. Sorry about that. This even could have impacted the print quality if one did not disable the error beeps. In the next version, beeps for network errors will be off by default.
Napsal : 23/04/2023 7:43 pm
rcjoy
(@rcjoy)
RE: Network Error on MKS+
PrusaConnect seems to be down at the moment.  But the local PrusaLink still works for network printing.
Napsal : 24/04/2023 3:48 am
Hello
(@hello)
I'd contact prusa through live chat as they might be able to debug on there server as it seems like a connection to there server error also try reflash image to sd
Napsal : 24/04/2023 8:41 am
Tojik
(@tojik)
Member Moderator
Napsal : 24/04/2023 9:04 am
1 lidem se líbí
ajbooter
(@ajbooter)
I was not getting any beeps just the ERR. I did not have any print failures either during this time. Currently, all is running as expected. Thanks for your help it is greatly appreciated.
Napsal : 24/04/2023 12:23 pm
Tojik
(@tojik)
Member Moderator
The first time around I missed the 0.6.1. The beeps start on 0.7.0RC1 and will end with RC4, but if our servers have a bad time, stuff like this will still show up on the LCD.
Napsal : 24/04/2023 12:40 pm
ajbooter
(@ajbooter)
Thanks for the clarification.
Napsal : 24/04/2023 3:31 pm
ajbooter
(@ajbooter)
The Network issue is back at this moment. All 3 machines show ERR.
Napsal : 24/04/2023 4:09 pm
Hello
(@hello)
Maybe try octoprint I've got it running on zero w with camera and plugins and it's fine
Napsal : 24/04/2023 7:38 pm
ajbooter
(@ajbooter)
Thank you for the advice. I actually like the Prusa Connect system a lot. I work in IT as an Enterprise Software Architect so I understand the issues that come up when running these types of enterprise systems. I would rather tell them my experience so it may help them troubleshoot and make the system better for not only me but for the community as a whole. I do appreciate the work Prusa has put into the system and it is still in Beta so I expect these kinds of issues. The data from the machines I have provided to them I hope is useful to them as well. I like the community Prusa has created and I hope to add something positive to it now and into the future. Maybe more than you wanted to know but that is my reasoning behind my decision to stay with Prusa Connect. Thanks again.
Napsal : 25/04/2023 1:29 am
Hello
(@hello)
yeah thats true i understand that too but some people out their are impatient and get angry for no reason so just thought id put it out their for other people
Napsal : 25/04/2023 4:47 am
Tojik
(@tojik)
Member Moderator
Sorry to correct you, you are using their instead of there. If it's on purpose or you just don't care then disregard
Napsal : 25/04/2023 9:21 am
Hello
(@hello)
Oh I'm really sorry I didn't even notice I will start making sure to use there
Napsal : 25/04/2023 7:33 pm
Tojik
(@tojik)
Member Moderator
No need for apologies, English is often confusing
Napsal : 25/04/2023 7:35 pm
