MK4 re-print
Fred
 Fred
(@fred-7)
MK4 re-print
Hello,
When you want to reprint after the previous print has finished, this is not possible unless you press the front button...
I'm getting an error message, what do I do if I've forgotten to press the button on the MK4 printer? With the MK3s, no problem.
Best Answer by Tojik:
Hi, the FW forbids the user from starting a print when not in the main menu. That should be changing soon.
I do not know, which message with a slider are you talking about. There is a message for when your filament, nozzle and so on are different from what the file is sliced for. What exactly is it reporting wrong? Reporting that it sometimes shows up when it shouldn't might be too broad to let us fix it easily.
Opublikowany : 31/05/2023 4:25 pm
Fred
 Fred
(@fred-7)
RE: MK4 re-print
I also sometimes get a message talking about nozzle diameter and filament with a slider (what's it for)?
Opublikowany : 31/05/2023 4:30 pm
Tojik
(@tojik)
Member Moderator
RE: MK4 re-print
Opublikowany : 01/06/2023 10:21 am
1 ludzie polubili
RE: MK4 re-print
Now that is unexpected — and excellent — news!!! This has been a real stumbling block.
Opublikowany : 03/06/2023 9:53 pm
